randomly lost spark!?
mikeemo240z
heres my situation. my car was running fine and was reving and all then all of a sudden the car died and now im not getting spark like i should. im getting a couple sparks when i turn the key on then one spark when i turn the key off but no spark while cranking? hel pwould be greatly appreciated. thanks
the coil is good and the hei4 module is good, i had to replace a resistor in the wiring from the dizzy to the relay board cause the sodar broke. so i thought that would fix it cause when i touched the broken sodar to the resistor it would start fine then cut off when the i pulled the wire off the resistor, so i replaced it and now it sparks twice when you crank the n one time when you turn the key off
