dpuma8 Posted November 24, 2012 Share Posted November 24, 2012 I habe the EZ wiring harness and I know the Z cars have ground switched high beams and turn signals. Is there anything special we have to do to make this work with ground switched items? Or is it pretty much plug and play? What about adding a relay for the headlights? I see there is a diagram on Atlantic Z on adding a relay so would wiring the headlights to EZ's diagram change the way I need to add the headlight relay? Quote Link to comment Share on other sites More sharing options...
dpuma8 Posted November 25, 2012 Author Share Posted November 25, 2012 Sure could use some help on this Quote Link to comment Share on other sites More sharing options...
ihiryu Posted November 26, 2012 Share Posted November 26, 2012 I'm not sure, but I'm sure you could use relays. So pretty much; 85-> Power 86-> Turn signal switch 30-> Ground 87-> Wiring harness So when the turn signal turns on and it supplies ground, it'll ground 30 pin to 87. Kinda of a pain considering you would have to wire two relays, but I'm sure that will work. Quote Link to comment Share on other sites More sharing options...
Snailed Posted December 8, 2012 Share Posted December 8, 2012 (edited) Is there a reason you can't just wire the lights in the GM/EZ wiring fashion? What parts of the Z wiring are you trying to retain? Maybe this will help; http://forums.hybridz.org/topic/109980-need-major-help-identifying-combination-switch-wires/ Edited December 8, 2012 by Snailed Quote Link to comment Share on other sites More sharing options...
dpuma8 Posted December 9, 2012 Author Share Posted December 9, 2012 No. there is not a problem with doing it their way. I am trying to learn to be a car guy and I wasn't sure if the combination switch along with ground switched items meant I had to do something different. SO just follow what EZ says to do and it will work? Quote Link to comment Share on other sites More sharing options...
Snailed Posted December 10, 2012 Share Posted December 10, 2012 (edited) I found this here, on Hybrid-Z. I have not tried this but it seemed to work for the guy that posted it. I don't remember who it was unfortunately. You should spend more time searching in the future. I just happened to be researching wiring stuff and saw this. Painless Wiring uses the same General Motors wire color code so these should translate to the EZ Wiring if you got the colored harness. If you bought the black one, just cross reference the color to function. Combo Switch----- Z Wiring Harness Main Color/Stripe Color ---->Color Painless # DescriptionLeft Signal post White/Black ------------> Lt Blue 949 Left Rear TurnLeft Signal post White/Black ------------> Yellow 926 Left Front TurnRight Signal post White/Red ------------> Blue 948 Right Rear TurnRight Signal post White/Red ------------> Green 926 Right Front TurnSignal Center Post Green ------------> Black 953 FlasherHead Light Power Red (heavy guage) ------------> Red/Black 925 HL 12vHead Light Power 2 Green ------------> Orange 959 HL 12vHigh Beam post Red/Yellow ------------> Light Green 908 High BeamLow Beam post Red/White ------------> Tan 909 Low BeamDimmer center post White/Red ------------> Blue/Yellow 907 High Low switchRunning Lights switch Green/White ------------> Brown 929 Tail LightsRunning Lights switch Green/White ------------> Brown 927 Front Park LightsRunning Lights switch Green/White ------------> Brown 930 Instrument Lights Edited December 10, 2012 by Snailed Quote Link to comment Share on other sites More sharing options...
