Seat Belt Points Help
docaam
Hi Guys,
The Z im doing is the first od my 240z experience and I have an issue in installing the seat belts.
I have a 1972 240z and when I shipped the car the seat belts came in a box uninstalled with the bolts intact, then i did the body work and finally did a dynamat in the whole car now all the stock hole are kind of under the dynamat, can anyone just post some pictures of the mounting points so I can follow it and drill the holes again. Really appreciated
Edited by docaam
Did you remove the seatbelt bolts? if so, you can push an awl thru the carpet thru the empty bolt holes from under the car. Then cut down along the awl (a cut off piece of clothes hanger would probably also work). Email me at pkeiththompson@yahoo.com and ill take some pics of my floorpans when I get off work. Ill send them as replied to your email address. I have 72 240z so should be the same.
