Refreshing a L28 question
Mycarispurty
I ordered a bunch of parts to fix up the outside of this 2.8 I bought to put in my 240Z. I got a water pump, thermostat, valve cover gasket, rear main seal kit, oil pan gasket, etc. I must have had a brain fart and ordered a timing cover gasket set thinking I needed to pull it to change out the water pump. I have a front timing cover seal coming with the kit I got and I definitely am going to replace the front seal while I'm up there, but do I really need to pull the timing cover for any of the freshening up?
The engine was running and driving so it doesn't need an oil pump and I don't plan on putting on a new timing chain, so I thought I'd see if there was any other reason to pull it and reseal it to the block if there was no real need to.
