Med Center Z Posted January 21, 2013 Share Posted January 21, 2013 I have a set of weber 40mm carbs that I'm using on my 3.0 l series. I currently have a walbro 255 inline fuel pump on my 240z running to a aromotive fuel regulator(with fuel pressure gauge). I have been reading that the first gen 79-83 rx7 fuel pump is a common swap while using carbs. I also found that the rx7 pump produces 3.7-4.7 psi. The question is can I regulate my walbro using my current regulator to let's say 5 psi give or take or will this damage the walbro 255 ? I hate to have to buy a new fuel pump all over again. Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted January 21, 2013 Share Posted January 21, 2013 You should not ever run that pump at that psi it will die very fast lol, get a low psi pump Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted January 22, 2013 Share Posted January 22, 2013 Nothing wrong with a stock mechanical pump for triple carbs. Quote Link to comment Share on other sites More sharing options...
AZGhost623 Posted January 22, 2013 Share Posted January 22, 2013 I have a Carter P4070 Competition fuel pump for my triples. Its not a direct replacement for the stock fuel pump bracket, had to fab some brackets to make it fit. According to the specs, its output is 4-6 psi, with 72gph free flow. No regulator is required. You can find it at Jegs for about 80$. I did a dead head setup on my triples, no return. Quote Link to comment Share on other sites More sharing options...
Med Center Z Posted January 26, 2013 Author Share Posted January 26, 2013 Thanks for the input. Quote Link to comment Share on other sites More sharing options...
Med Center Z Posted January 26, 2013 Author Share Posted January 26, 2013 I'm reading throughout sever LS forms that several people are lowering the PSI on the Walbro 255 and having no issues. They are using carb's and running 5-6 PSI all day on a regulator. Quote Link to comment Share on other sites More sharing options...
Med Center Z Posted February 16, 2013 Author Share Posted February 16, 2013 How is this possible to not use a return fuel line ? How do the carburetors operate when the fuel pump is constantly fluffing the bowls with fuel wouldn't the carbs get to much fuel ? And it seems to me that running the return would benefit in reducing the temperatures of the fuel resulting in a better burn resulting in more HP/TQ Educate me.... Quote Link to comment Share on other sites More sharing options...
duragg Posted February 16, 2013 Share Posted February 16, 2013 I have a dead-head setup and it works ok. I think a return is superior since you can pump cooler fuel through, which is of marginal value since the headers are nestled comfortably between the float bowls. The needles shut off the fuel when the bowls are full. Personally I think fuel delivery / pressure gets over analyzed. Supply adequate quantity fuel under moderately low pressure and it seems to be just fine. Quote Link to comment Share on other sites More sharing options...
