Found a brake switch to use with auto trans. conversion
For those who are doing V8 swap with auto trans. , I've found this switch to replace stock brake switch . You'll need this for your brake lights and TCC signal to your ECM . Will work on the S30 and maybe other ZXs . It's only $15 . If you have a junk Toyota , check out the brake switch . Most have four wires and two sets of contacts .
Edited by Domzs
