Guest Anonymous Posted October 27, 2001 Share Posted October 27, 2001 im looking for a head and cam combo for a stock 72 240z. i just want to add some more power, nothing real drastic, maybe up to 180 at the wheels or something around there.i decided against a turbo, so please keep that in mind. ive got headers and a 2.5" exhaust on it now. however, i have the stock carbs. are these in need of a change as well? any help is much appreciated. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted October 27, 2001 Share Posted October 27, 2001 I tell you what, my old setup was similar to yours, 2.5" exhaust, 6-1 headers, filters, MSD ignition and coil. I swapped in the Motorsport auto 290dur cam and it was a huge difference. I also had the the flattop 2.8 bottom end. Quote Link to comment Share on other sites More sharing options...
Guest norm[T12SDSUD] Posted October 27, 2001 Share Posted October 27, 2001 Hey Ken, I used to run an old 2.4L with my modified N42 head and it ran a 13.6 @ 99 mph in the 1/4 on street tires so it was making close to 200 HP at the flywheel. Get an N42 and shave it around .070" to .080" and install a decent cam. I used a rather mild 272/282 .450" lift Crane cam so if you go with a more radical cam maybe you can make closer to 210 HP at the flywheel. Also you will need to install a 3.9 rear end to make up for the loss in low rpm torque of the cammed up engine. Later,norm Quote Link to comment Share on other sites More sharing options...
Guest norm[T12SDSUD] Posted October 27, 2001 Share Posted October 27, 2001 If you use this combo be certain to grind in valve reliefs in the block as the valves will definitely hit the cylinder walls unless that is done!! Later,norm Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 27, 2001 Share Posted October 27, 2001 wow! thanks, i really appreicate it. does the fact that it is an automatic have any say in to my final decision? Quote Link to comment Share on other sites More sharing options...
Guest Zpeed Posted October 28, 2001 Share Posted October 28, 2001 Norm, i've been following your post for a while, and i just write everything down that you say, because i'm going to try and copy your setup, also with a few nitches of my own.. thanks norm Quote Link to comment Share on other sites More sharing options...
