CrayZ Posted March 20, 2013 Share Posted March 20, 2013 I have a couple questions regarding sensor placement. I have an lq4 in my 77 and im wanting to put an autometer oil temp guage and a trans temp guage. Can anyone point me in the easiest direction to installing these sending units? Quote Link to comment Share on other sites More sharing options...
Domzs Posted April 3, 2013 Share Posted April 3, 2013 You can tap the oil cooler block off plate ( at the oil pan ) for your temp. sender . Trans. pan is one location for trans. temp. sender or put a splice in your trans. cooler hose ( make sure you have a ground if your have a single wire sender ) . Quote Link to comment Share on other sites More sharing options...
CrayZ Posted April 6, 2013 Author Share Posted April 6, 2013 (edited) Im trying to avoid pulling the pan and tapping it. I was hoping there was an easy access port already on the trans. Ive heard about tapping the oil cooler blocl off plate but again was hoping there was a plug somewhere on the motor that i could throw a temp sensor in its place. Edited April 6, 2013 by CrayZ Quote Link to comment Share on other sites More sharing options...
Domzs Posted April 6, 2013 Share Posted April 6, 2013 I would wait until you are ready for trans. filter change to install your sender ( for trans. temp. gauge ) . Corvette C5 has temp. sender installed at oil cooler block plate . Where's your oil press. sender ? Quote Link to comment Share on other sites More sharing options...
CrayZ Posted April 6, 2013 Author Share Posted April 6, 2013 I've also heard of people using the drain plug for a temp reading for the trans. Might give that a try when it's time for a change. The oil pressure comes from a removed plug in the valley at the rear of the motor. Quote Link to comment Share on other sites More sharing options...
