mikesv8z Posted March 31, 2013 Share Posted March 31, 2013 I need a little info for my motor install . My motor is a 1989 iroc 350 tpi motor originally . I purchased the correct water pump for that motor ,but I am not using the serpentine belt that was on the motor . If I use a traditional belt it will turn the pump the wrong way . Can I use a pump that rotates cw ,or will this affect flow ? Quote Link to comment Share on other sites More sharing options...
Zinpieces Posted April 1, 2013 Share Posted April 1, 2013 I'd say change the pump. When you buy a serpentine kit they send you a reverse flow pump. Stands to reason that going from serpentine to standard is going to require changing the pump. Quote Link to comment Share on other sites More sharing options...
