Domzs Posted April 18, 2013 Share Posted April 18, 2013 I'm glad you found and fixed your problem . I would check your TPS at idle to see if it's within spec. and throttle stop to make sure the throttle blade it's not open too wide . Quote Link to comment Share on other sites More sharing options...
Vandergriff84 Posted April 18, 2013 Author Share Posted April 18, 2013 I'm glad you found and fixed your problem . I would check your TPS at idle to see if it's within spec. and throttle stop to make sure the throttle blade it's not open too wide . How do you know if you have the throttle blade in the right place? Quote Link to comment Share on other sites More sharing options...
Vandergriff84 Posted April 18, 2013 Author Share Posted April 18, 2013 I have been all over the car looking for vacuum leaks and I get know change in idle except for the very back side of the intake plenum flange it idles lower or rougher when I spray there. It is my understanding that spraying carb cleaner will make it rev when sprayed near a leak. I hear a whistling sound slightly and when I rev the engine it gets a little louder. I think it is coming from the IAC and when I pinch the PCV hose it goes away. Quote Link to comment Share on other sites More sharing options...
Domzs Posted April 18, 2013 Share Posted April 18, 2013 How do you know if you have the throttle blade in the right place? You have to check the fact. spec. Sorry i can't get any info on RBs at my shop . Quote Link to comment Share on other sites More sharing options...
