Guest Anonymous Posted December 15, 2001 Share Posted December 15, 2001 got a quick question. i got a msa header and in there catalog they state that you need to buy there high performance gaskets. how does this gasket differ from a normal one and what is their reasoning in saying that u need a special one?? thanks in advance dave Quote Link to comment Share on other sites More sharing options...
Guest norm[T12SDSUD] Posted December 16, 2001 Share Posted December 16, 2001 The stock Nissan gasket works the best and lasts the longest with headers. Myself and others on the board can attest to this fact. MSA just wants to make a couple extra dollars. LAter,norm Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 16, 2001 Share Posted December 16, 2001 thanks norm that is what i figured i just wonted to check Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted December 17, 2001 Share Posted December 17, 2001 I've got three stock 280Zs and I ditto what Norm says!! Quote Link to comment Share on other sites More sharing options...
johnc Posted December 17, 2001 Share Posted December 17, 2001 Well... The high performance hader gasket sold by MSA is the Nissan Comp one (I think). It is the only one that will retain its integrity when you grind on it while port matching the header to the head. Quote Link to comment Share on other sites More sharing options...
Guest norm[T12SDSUD] Posted December 18, 2001 Share Posted December 18, 2001 Yes, very good point by John. If you have ported your heads then in order to port match the header gasket you will need to get the fiber header gasket as the stock gasket is next to impossible to modify. To make you fiber header gasket last longer coat it with copper spray before installing it. Later,norm Quote Link to comment Share on other sites More sharing options...
