intake deposits?
i have my intake off to clean things up a little bit and i noticed that they is deposits of some sorts inside the intake from where it meets the head all the way to the TB not sure what it is??
Guest Tom Scala
I had the same thing in mine. It was from a bad PCV valve sucking oil out of the crankcase up to the intake. It must have been happening for years because it was baked on and was tough to clean out.
I'm not sure. My racing motor burned a quart of oil every couple hours of use yet had very little blow-by. The intake manifold and intake ports were spotless. I did run Mobil 1, changed the oil after every event, and ran the stock PCV system. The valve cover vent ran to a catch can (per the rules.)
For some reason I'm thinking that intake deposits are mostly the result of fuel, not oil. But, I'm a suspension guy. Motors are just things that make the car go forward.
