Turbo install questions????
I am at the end of my install and trying to get the wiring done.
1974 Datsun 260z that had 2 carburetors.
1. Where do the coil wires connect onto the ECU? Have a coil from a 1983 280zxt.
I was told that you get the 280zxt washer fluid wiring harness and plug that into the coil or make your own harness which I can. So if I make my own 2 wire harness for the coil, where do these wires goto?
2. Fuel relay- this picture is what I have coming out of the wiring harness. I am sure that the green relay is the fuel pump relay. What is the white 6 connector that is attached by a black with white stripe wire to the fuel relay? Are those the wires I am suppose to run to the fuel pump?
3. Should the fuel injectors have juice when the key is not on?
I am so close to starting the car!
