Problems with four barrel conversion
I'm putting a Holley 390cfm carb on an Arizona Z intake and noticed the linkage on the carb hits the intak and you can't open it full throttle without using a space in between the carb and the intake. There is also a different number of bolt holes on the intake then what the stock manifold had. Are there any other problems I will run into while doing this?
sorry to not get back to you. I lave mine but I have the Bob Sharp one. I use a ford 2 bbl carb and a custom cable made with moutain bike "V-Brake" cable parts. Works very nice. Never have linkage in my car for throttle agian.
I am not sure about your questions aout the fit but Dave (AZZCar) will help if you call him.
jake
sorry everyone for the multiple posts....you may have a problem with the flange thickness of the intake compared to that of the header. Measure good with acurate tool because they share bolts.
