Dan Baldwin Posted January 28, 2002 Share Posted January 28, 2002 Hey all, I might be buying a set of 45mm SK carbs, bought in Japan. Seems they were only available in the states for a few years. Just wondered if anyone had any direct knowledge as to whether or not Weber pilot, main, and air jets drop in, as I don't think SK parts would be readily available. Thanks, Quote Link to comment Share on other sites More sharing options...
Ruben Posted January 31, 2002 Share Posted January 31, 2002 Dan, The following SK Carb parts are interchangable with the Weber DCOE carbs: Main jets Air correctors Idle jets Emulsion tubes Pump exhaust valves Pump rod, spring and piston Auxiliary venturis (45 DCOE only) The following are interchangable with Mikuni PHH late model carbs: Pump jets (Mikuni calls these pump nozzles) Floats Needle Valves Fuel Union Banjos (I think Mikuni calls these Fuel Pipe Assy) Hope this helps. Let me know if you have any more questions. Ruben '72 240Z Quote Link to comment Share on other sites More sharing options...
Dan Baldwin Posted January 31, 2002 Author Share Posted January 31, 2002 Thanks, Ruben. I have a feeling this is going to be a challenge getting the 3X2 dialed in. Quote Link to comment Share on other sites More sharing options...
JSM Posted April 25, 2007 Share Posted April 25, 2007 Dan, I just picked up a car w/SK carbs. Did you ever find a source for the SK parts. Thanks Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted April 25, 2007 Share Posted April 25, 2007 Go to TWM induction in Goleta CA that I got my gaskets from, they use to import SKs. They have a web site. There is someone on Ebay that is selling what looks like SKs for about $2K. I do not know if they carry parts. Gasket is all that you will need. Quote Link to comment Share on other sites More sharing options...
JSM Posted April 26, 2007 Share Posted April 26, 2007 Thanks I think my tag may be readable. I'll have to check. You have the auction number handy? Quote Link to comment Share on other sites More sharing options...
