Guest Anonymous Posted April 21, 2002 Share Posted April 21, 2002 If I want to put the engine from my 81 turbo in another car, which car should I choose? I want a car that will offer the best mix of hiway calmness and road track handling. I understand the 280z's are pretty good in that respect. however the lightweight of the 240 appeals. one more thing- when I put my engine into a car with a manual tranny (the engine is currently paired with an auto) do I have to change anything to accomodate the input shaft? thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 22, 2002 Share Posted April 22, 2002 I just did that same swap and you will need a pilot bushing because they didnt use one on the auto trans. i put a 78 5speed on an 81zxt motor and dropped it into a 71 240.I got a pilot bushing for a 78 trans it didnt fit into the hole in the crank so I had to turn it down on a lathe and then tapped it in place.I should have gone with a bushing for the 81 motor but then again I dont know if the ID is the same as the tranny.Also theres a 1/8" plate thats between the torque converter and the crankshaft that needs to be taken out when you install the manual trans. Its like a shim with the same bolt pattern as the converter or flywheel. By the way, spring for an aluminum flywheel it'll help with lag/spool-up. Quote Link to comment Share on other sites More sharing options...
johnc Posted April 22, 2002 Share Posted April 22, 2002 240 would be the best choice because of the lighter weight. How the car feels on the highway is more a function of spring and shock choices than the chassis. Quote Link to comment Share on other sites More sharing options...
