L28 will not stay running
logo113
Actually, when I fixed the engine size from 1753cc to 2800cc and re-did the fuel calculation, the required fuel went up to 16.9ms. I have tiny injectors (stock ones,185cc I think). So they should be open longer vs 440cc injectors.
Should I generate a VE table or just use the one that came "in the box" ?
That sound about right. The calculations are to get you near 100% at full load. Ihave mine tune that way. The calc fule is just a guide. mine is set for 100% fueling at around 4000rpm at 100% load. The when it goes into boost obviously more than 100%. With that pulse width, you be be very close to maxing them out, Max P/W at 6000rpm is 20ms.
  • 4 weeks later...
