Guest Anonymous Posted July 22, 2002 Share Posted July 22, 2002 I installed an electric fuel pump and a fuel pressure regulator and I was wondering what pressure should I set the regulator at. Its an L28 with SU carbs. Thanks Lance Quote Link to comment Share on other sites More sharing options...
Dan Baldwin Posted July 23, 2002 Share Posted July 23, 2002 How to Modify book says 3 - 3.5 psi, but the crew chief behind the fastest ITS car in the country told me 4+. Mine are at 4. Quote Link to comment Share on other sites More sharing options...
Guest HIGHRPM Posted July 26, 2002 Share Posted July 26, 2002 I've tried my 260 at several different pressures and found that 4 pounds worked the best.I found with my setup that 4.5 pounds flooed my fuel bowls as the needle and seat couldn't hold it back and at 3 to 3.5 there was a lean period at WOT. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted July 27, 2002 Share Posted July 27, 2002 Mine are set at 3 psi right now, according to my summit fuel pressure gauge. The regulator is set at 4 psi. Not sure what is up with that, but I enlarged the hole in the return line of my fuel rail so it would flow all the time. Keeps the gas cool, and the fuel filter full as well. Quote Link to comment Share on other sites More sharing options...
