sticking throttle body!
Got a big throat body from twm. thing is ill slowly gas it to around 3000rpms and it sticks!! Put a new spring on it, and a return spring just in case, lubed everything. Nada. Now i think ive sourced the problem just need some help on how to fix it. I found that the shaft, and the arm that the cable pulls has a little play in it. Should a new shaft and arm remedy this or what??
thanks in advance,
franklin
p.s. also if anybody else is using this setup on a turbo car. Should the throttle plate be fully closed for idle and the idle screw be turned mostly open. Or should the throttle plate be opened a tad, and the idle screw mostly turned closed??? stumped!
