How to hook up my Camaro gas tank into a 78 280Z
smoorenc
I am looking for some guidance here on hooking up a camaro gas tank I use to have on the LS1 '76 into the newer '78 L28.
I can hardware mount it fine just not sure about the fuel. Originally I used the Corvette fuel filter/regulator for return for the LS1 setup. For the LS1 do you think I would just come off the fuel pump in the tank to the feed line after the 280z pump and then the return from cars regulator to the tank return line?
Would you think the original regulator would work with the camaro fuel pump?
Thanks
Scott
