DAW Posted August 9, 2002 Share Posted August 9, 2002 Use a water temp sensor as the '79 (and earlier L28s) had. It's located in the thermostat housing on these earlier heads. Just splice it into the harness for the cyl head temp (your '81 connector won't reach to the thermostat hsg). The thermistors are the same, you'll be inputing very similar values (water temp vs cyl head temp) and the ECU probably won't know the difference. Don't put the sensor in the intake manifold! DAW Quote Link to comment Share on other sites More sharing options...
David K Posted August 9, 2002 Author Share Posted August 9, 2002 thank you. i did the manifold thing and it ran very rich. it was picking up the cold air inside, thus it smelled VERY rich. now, what if we did this on turbocharged engines? would the extra fuel help out a bit? Quote Link to comment Share on other sites More sharing options...
David K Posted August 10, 2002 Author Share Posted August 10, 2002 hey guys im using a head off a 79 and it doesnt have the head temp sensor. problem is that im running an 81 ecu and it needs to read the temp. can i take the head sensor i have from another head laying around and screw it in the intake manifold and get almost the same readings fromt here as i would get from the head? thanks guys. Quote Link to comment Share on other sites More sharing options...
DAW Posted August 11, 2002 Share Posted August 11, 2002 Too eratic. Matching the cyl head/water temp input modification to modification of the temp sensor for the AFM can increase richness through out the rpm range if it's needed, but this technique is for small amounts of extra fuel and not for load-based (turbo) tuning. DAW Quote Link to comment Share on other sites More sharing options...
David K Posted August 12, 2002 Author Share Posted August 12, 2002 ok forget the sensor stuff. i searched the garage today and found some brown top injectors and replaced the ones on my motor with those. turns out i had 2 lame injectors, thats why it was running like it had bad readings from the temp sensor. cheers! Quote Link to comment Share on other sites More sharing options...
