Some questions about making power from the 280ZX turbo motor
Guest ON3GO
ok guys im still looking for ideas on different motors for my 240Z.
So far its tied between the LT1 and the SR20DET.
I know you can make power from the factory 280ZX turbo motors....sooo.. whats the parts needed to make it a 11sec motor?
I want a car i can drive everyday and not have to worry about ET streets or any type of tire besides reg street tires.. smile.gif
needs to be a stick too..
so any help would be great.
mike
These include, but are not limited to,
higher compression forged pistons
more than likely a metal head gasket (such as HKS)
larger turbo (probably at least a T04E)
head porting/polishing, possibly oversized valves
higher degree camshaft
front mount intercooler (FMIC)
larger injectors
adjustable FPR
Possibly some type of engine management
heavy duty clutch
Limited slip R200 rear end, you may consider a 3.90
Now, some people have probably run 11's without everything in the above, or using some stock components, but, I believe they are the exception, not the rule...
