R200 4.11 or 3.90 which should I use??
Guest Xtinc
I have a '72 240Z w/ L24 and will be installing a later ZX 5 speed trans. Should I go with the 4.11 or the 3.90 gear diff? I don't know a whole lot about the gear ratio thing - would I see a big difference between the two? I've never driven anything, but the stock 4sp and rear end.
Thanks
I can't get a 4.11 into http://www.geocities.com/z_design_studio/
so I ran it through my spreadsheet.
70-79 have a .864 5th gear.
1980 have a .775 5th gear.
81-83 have a .745 5th gear.
Makes a difference! So does tire size! I like the 3.90 with my 81 trans and 225/50R14 tires on street, hwy, and track. 129mph@5500, 70mph@3000 The 4.11 gives faster acceleration and 122mph@5500, 67mph@3000. About the same but 3.9 is more available and cheaper. You can get a lot out of a decent R180 or R160. You dont HAVE to have a R200. Save $100. If I had a .864 5th I'd get the 4.11 because the 3.90 is 101mph@5500, 61mph@3000. BTW bigger diameter tires will raise the speed and slow the acceleration. HTH
