multiple problems related to the cold...HELP!
Guest BadKarmaCreepin
Sounds like the ignition was stuck in the 'start' position and the starter was engaged.
Try one of two things:
1. get some dry graphite lubricant and lube the starter tumbler
2. get a push button starter button and bypass the ignition switch.
Tim
thanks! i found out i burned the starter completely. car won't start. so i need to shell out 89.99 + core (until i bring in the old one) to get a rebuilt sucker. how hard is it to replace? what needs to be done? i want to get it and do it tonight so i can still get to work tomorrow. hopefully i don't need to jack the car up...
Pretty easy job, but you will probably need to get the car in the air a little....the on board jack (spare tire one) should be ok. Disconnect the battery and the two wires on the starter and two bolts and out it comes. Stop by a JY if you can...there should be lots there for much cheaper, and these starters are pretty robust, so a used one will probably last a long time.
Tim
