I found a diesel L-motor. In a Maxima
Guest JAMIE T
I was wondering if it would be worth me pulling the engine out of this Maxima at the junk yard to get the crank. I don't know much about these Nissan 6's, but I've read alittle about using this crank for building a 3 liter stroker motor. I will pull it if you guys think I should.
Also, this car has the correct offset bolt-on rear caliper brackets for installing discs on the back of a Zcar. The build date is 3/81. I'm pulling those for sure.
Guest bigjim240z
get it..if you hesitate it will be gone!..i found one and within 4 hours of me going home and saying to myself.."get that crank"..i went back and found the engine on the floor with the crank ripped out!..see ya jim
  • 1 month later...
