Ylo73z Posted April 2, 2014 Share Posted April 2, 2014 I picked up a long nose r200 with 3.91 gears on eBay ...I want to swap it into my 280z , it has a plastic end with abs sensor added to the snout held on with 4 bolts , the input flanges look different so it doesn't appear my flange will swap ...it also doesn't have axles , will my fit ? Can I just unbolt the plastic piece and use my flange ? Quote Link to comment Share on other sites More sharing options...
logr Posted April 2, 2014 Share Posted April 2, 2014 What is the diff out of? Quote Link to comment Share on other sites More sharing options...
Ylo73z Posted April 2, 2014 Author Share Posted April 2, 2014 Don't know ...based on research it appears to be out of a Infiniti m30 ...it has a 4 pinion carrier and a nice gear ratio ...if the axles are the same worst case scenario I can just have the input flange modified to accept my driveshaft Quote Link to comment Share on other sites More sharing options...
Ylo73z Posted April 6, 2014 Author Share Posted April 6, 2014 It's the same ....plastic piece unbolted and all my axles and flanges transferred over no problem Quote Link to comment Share on other sites More sharing options...
