Custom headlights , your thoughts ?
Here are few night shots , not completely dark outside . It's hard to see the halos , too bright .
With headlights on , can't even see them .
They look better in person , too bright for the camera to pick up the halos .
They have some.  As I just got through looking for some for a set of lights.  It is a 2 part that is clear, but you have to worry about UV light potentially fading it.  It would be best to epoxy and paint if you are up to it.  I don't have the numbers of the stuff we used,  but it is a 3M product.  It was up on a big chart at my local auto paint supplier, Tasco....
FWIW, I found a 150mm COB halo that fit nicely _inside_ the headlight.  I'm using the same headlight that Domzs is using, and carefully removed the glass cover and placed the halo inside, as the 150mm size was a pretty good fit for this:
I used the grey "Right Stuff" adhesive to tack the halo in place and then seal the glass cover back up.  Here's a couple more pics:
Edited by TimZ
