Moridin Posted November 11, 2002 Share Posted November 11, 2002 Eventually I want to do a V8, but I need to replace the radiator pretty soon. Much sooner than the V8 going in. Anyways, any suggestions. I thought about getting a Griffin or another popular brand. I know a little bit about the subject, but not enough to make a good decision. Anyways thanks for all your help so far with everything. Quote Link to comment Share on other sites More sharing options...
Dragonfly Posted November 13, 2002 Share Posted November 13, 2002 In my stroker I am running an aluminum radiator from a Fiero, I am also running the Fiero fan which just happens to be a two speed fan. The radiator is NOT a direct bolt in but it is not difficult either. If you decide to go this route make sure to find a Fiero with an all aluminum radiator (and plastic side tanks) not the combination brass/aluminum with brass side tanks. Get the radiator, complete upper support, fan (if you want to go that route), and the rubber radiator mounts from the lower support. I made my own lower support and I modified the upper support to allow me to bolt it into the car, on the fan I trimmed down the plastic on the sides so it would fit closer to the radiator to allow the minimal clearance I have between the fan and the water pump, I also drilled two holes in the top of the radiator support so I could bolt the fan directly to the radiator. All the above may seem a little confusing but with pictures it would make more since, unfortuanetely I do not have a digital camera or a place to put the pictures even if I had them, but if you decide you want to try this set up let me know and I will give you all the help and details I can. Dragonfly Quote Link to comment Share on other sites More sharing options...
Moridin Posted November 13, 2002 Author Share Posted November 13, 2002 Thanks a lot for the info. I'm going to start hitting the junk yards in Rancho Cordova to get a part collection going for the 240 build up. Thanks again. Quote Link to comment Share on other sites More sharing options...
