Megasquirt II programing problems PLEASE HELP
Tim H
I bought a MS II assembled from DIY coil driver installed by DIY.
my problem is hooked up to JimStem board I can not get a consistent engine rpm.
also the fuel pnmp light is not steady it flickers at the same rate as the injector banks.
please help
The fuel pump flickering steadily on the board would indicate MS is pulsing the fuel pump. This is a sign of a important software misconfiguration. Like your wheel/distributor settings are wrong or you have the wrong number of squirts configured, etc. Something massive that would not let the car run because it conflicts with reality.
