thezguy Posted June 25, 2014 Share Posted June 25, 2014 Does anyone have a line on a thicker sway bar to fit The TTT rear LCA's? Does the stock one fit there as well? Quote Link to comment Share on other sites More sharing options...
Rob L Posted June 25, 2014 Share Posted June 25, 2014 Im not sure i follow but the only thing that the sway bar and ttt lca have to do with eachother are the links .....so regardless the thickness of bar its just the links that get connected to the LCA..... Quote Link to comment Share on other sites More sharing options...
thezguy Posted June 25, 2014 Author Share Posted June 25, 2014 Im asking if the TTT LCa's accomodate the factory sway bar. I am also asking for a source to a thicker/stronger rear sway bar. Quote Link to comment Share on other sites More sharing options...
30 ounce Posted June 25, 2014 Share Posted June 25, 2014 Yes they can work with the stock bar, MSA bar (which is what I run with my TTT setup), or ST bar. Quote Link to comment Share on other sites More sharing options...
thezguy Posted June 25, 2014 Author Share Posted June 25, 2014 On 6/25/2014 at 9:59 PM, 30 ounce said: Yes they can work with the stock bar, MSA bar (which is what I run with my TTT setup), or ST bar. Thank you Quote Link to comment Share on other sites More sharing options...
thezguy Posted June 25, 2014 Author Share Posted June 25, 2014 On 6/25/2014 at 9:59 PM, 30 ounce said: Yes they can work with the stock bar, MSA bar (which is what I run with my TTT setup), or ST bar. Did you notice a big difference when you swapped bars? Quote Link to comment Share on other sites More sharing options...
30 ounce Posted June 26, 2014 Share Posted June 26, 2014 On 6/25/2014 at 11:05 PM, thezguy said: Did you notice a big difference when you swapped bars? Since I did the whole suspension at once it was huge. Quote Link to comment Share on other sites More sharing options...
thezguy Posted June 27, 2014 Author Share Posted June 27, 2014 On 6/25/2014 at 11:05 PM, thezguy said: Did you notice a big difference when you swapped bars? Did you swap the whole rear suspension with TTT components? if so can you send me a picture of how yours is setup? Quote Link to comment Share on other sites More sharing options...
30 ounce Posted July 1, 2014 Share Posted July 1, 2014 On 6/27/2014 at 4:26 AM, thezguy said: Did you swap the whole rear suspension with TTT components? if so can you send me a picture of how yours is setup? http://forums.hybridz.org/garage/vehicle/330-datsun-260z/?tab=images# Here you go... Quote Link to comment Share on other sites More sharing options...
thezguy Posted July 3, 2014 Author Share Posted July 3, 2014 On 7/1/2014 at 1:41 AM, 30 ounce said: http://forums.hybridz.org/garage/vehicle/330-datsun-260z/?tab=images# Here you go... Nice car, thanks! Quote Link to comment Share on other sites More sharing options...
