Guest Anonymous Posted December 8, 2002 Share Posted December 8, 2002 OK, first appolgies for not putting this in "Ignition"........couldn't decide which. That said, I'm about to put a ZX Dizzy (E12-80 module) in my 260Z replacing the standard early electronic distr. I find lots on how to wire it, but I can't find anywhere whether I should wire it through the existing ceramic conector block off the coil, or go straight from the coil to the new distributor. (Sounds like I can bypass the ceramic, but I don't want to fry the module, thus the question.) Thanks, Randy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 12, 2002 Share Posted December 12, 2002 bypass the ceramic block Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted December 12, 2002 Share Posted December 12, 2002 Yep, run it straight from the coil to the ignition module. It is a nice cheap upgrade from the points type distributor. Quote Link to comment Share on other sites More sharing options...
