78 280z transmission
Guest ottocycle
Following the introduction in 1977, the 5 speeds were originally considered to be weaker than the 4 speed but after all these years the weak sisters in the 5 speeds did not survive. The 5 speed is slightly longer requiring a shorter drive shaft. I once put a "shorter" 4 speed from a 620 pickup in a OEM equipped 5 speed 1977 280 that (5 sd) failed. Your car may have been originally equipped with a 5 speed. I used the OEM "short" 5 speed drive shaft with the pickup tranny.5 speeds tend to place less wear on the engine with the fifth gear. I found 620 pick-ups with 5 speeds had the best motors.
Guest ottocycle
Was the 1978 280z offered with a 4 speed manual transmission or only a 5 speed? I'm currently looking to buy a 78 z and it appears to have a four speed in it. I've read that the 5 speed in the 77/78 280z's had problems with the fifth gear (something to do with the shift fork). Could this be the case with the car I mentioned?
Thanks
