Guest christo Posted January 3, 2003 Share Posted January 3, 2003 Does anyone have an idea what the max compression a L28 0.040 over,cast flat tops, around 105 -108 octane can reliably produce before implosion. Quote Link to comment Share on other sites More sharing options...
Guest norm[T12SDSUD] Posted January 3, 2003 Share Posted January 3, 2003 Well I can tell ya from personal experience that going over 11:1 on 93 octane street gas will break many a piston ringland. However if you are going to be running 105 octane then I see no reason why 13:1 wouldn't be possible, although ringland integrity on the stock pistons may be questionable at that level even without encountering detonation. later,norm Quote Link to comment Share on other sites More sharing options...
johnc Posted January 3, 2003 Share Posted January 3, 2003 It depends a lot on your cam. I'm running 13.6-1 and I have detonation problems with anything less then 108. Normally I run 110 leaded. Here's some information about high compression: http://www.motortecmag.com/archives/2001/jun/JUN01-01/JUN010101.html - John Quote Link to comment Share on other sites More sharing options...
Guest christo Posted January 3, 2003 Share Posted January 3, 2003 Excellent info. Thanks, L28 crank, 240 rods,big valves,87mm flatops, E31 milled head,500 L / 300D cam 45 mm Webers and some sweet 110 VP and Bobs your uncle Sounds so easy. Chris Quote Link to comment Share on other sites More sharing options...
