ktown z Posted August 24, 2014 Share Posted August 24, 2014 I am about to install my turbo upgrade and need some advise on some injectors. I run rc engineering in my turbo 350z and was considering buying a set for my rb26dett. Will the rc eng. injectors fit the stock fuel rail and wiring clips? Thanks, James Quote Link to comment Share on other sites More sharing options...
ihiryu Posted August 26, 2014 Share Posted August 26, 2014 Weird, someone else from Killeen. Anyway, the RB20/RB26 rails use a 10.5mm while the RC Injectors (if memory serves me correctly) is 11.0mm. Also you have to keep in mind that the stock injectors are tapered (meaning the diameter changes), due to the O-Rings Nissan uses on the rails. If you were looking for drop in injectors I would suggest the DeatschWerks, however you should talk to your tuner to see how they feel about it. Alternatively you could just buy a fuel rail and use the RC injectors. (insert shameless plug) if you would like to purchase some injectors I'm a dealer for both DeatschWerks and RC, and could help you out with pricing on either. Quote Link to comment Share on other sites More sharing options...
ktown z Posted August 28, 2014 Author Share Posted August 28, 2014 Is your shop located in Killeen? It's good to see someone else from my hometown on this forum. Quote Link to comment Share on other sites More sharing options...
