mkl12310 Posted September 18, 2014 Share Posted September 18, 2014 So I can't seem to figure out this electrical problem. My turn signal switch worked for a while and then stopped working. Park lights still work when the headlights are turned on and hazard lights work, The brake lights worked for a while but recently stopped working as well (not sure if caused by turn signal problem) So I tried cleaning the connections by following this write up: http://fiddlingwithzcars.wordpress.com/2012/12/04/turn-signal-repair/ and after they still don't work. So i borrowed a turn signal from another 72' 240z and still nothing so it has to be before the switch. Haven't had the chance to follow the wire and i'm not really looking forward to dealing with electrical since i just fixed an alternator problem which was a headache. Any input is appreciated. Quote Link to comment Share on other sites More sharing options...
nullbound Posted September 18, 2014 Share Posted September 18, 2014 (edited) Does your hazard switch work? You should also read this post from the same site: http://fiddlingwithzcars.wordpress.com/2013/01/20/hazard-switch-brake-light-turn-signal-circuit-analysis/ Edited September 18, 2014 by nullbound Quote Link to comment Share on other sites More sharing options...
