BlueStag Posted September 19, 2014 Share Posted September 19, 2014 Sorry, I NEVER can seems to post on the transmission page for some reason. You may know of my Triumph Stag with a L6 and a Maxima 4sp trans. The flex plate started breaking up about 3 months ago. I managed to pull it apart and put it back together. Gotta work out the shift linkage a bit, but not your problem! I think I lost a washer or gasket. The trans is dumping rather prodigiously fluid from the speedo gear head. I have cranked down on the bezzle that locks the trans cable in place, it is tight, but the cable itself is loose, and fluid is escaping. The Nissan dealer was less than useless, of course. Does anyone know if there is supposed to be a gasket of some sort in there? I imagine something like a hose gasket. If anyone has some of this stuff kicking around that is not attached to a car, and can observe, and possibly give me dimensions. And what sort of material? I imagine that many rubber like products would dissolve fairly quickly in that environment. Thanks as always. Quote Link to comment Share on other sites More sharing options...
