Weld in JCI mounts
You do not want to weld in JCI mounts. The driver side mount actually requires you to remove the back of TC Cup in order to install it. If you ever wanted to drop the crossmember, then having everything welded together, even if you did not weld the piece to the back of the TC cup, would be difficult.
