s30kid Posted October 4, 2014 Share Posted October 4, 2014 Hey guys I have some questions I cant seem to find answers too. Here is my setup 1977 280z f54 block with a n47 head megasquirt 2 v3.57 with relay board stock injectors (soon to buy 515cc supras, but for now I might just bump the pressure with low boost) 280z distributor and coil stock turbo manifold stock turbo msa 2.5" downpipe Mishimoto 3" intercooler (I don't remember the dimensions but its large) And I am having my intercooler piping built by mckinney next week. all I need now is a trigger wheel and sensor. My first question is can I run the 36-1 tooth wheel from diy autotune mounted to the crank pulley and use megasquirt to fire the coil? From my point of view I don't see a reason why it wont work as long as I disable the mechanical advance. Next question is.. how do I set the timing.. With the 36-1 wheel would the missing tooth be TDC Cylinder #1? I was reading another topic on the subject and he said he was using the 5th tooth but I don't remember.. Thanks for taking the time to read this any help is appreciated Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 7, 2014 Share Posted October 7, 2014 For the first question - yes. You can even leave the mechanical advance in place as it will help with rotor phasing. You'd use a timing light to set the timing. Just adjust the Tooth #1 Angle setting until the timing you see on the timing light matches the timing in TunerStudio. Quote Link to comment Share on other sites More sharing options...
s30kid Posted October 13, 2014 Author Share Posted October 13, 2014 So it doesn't matter how I mount the trigger wheel? The missing tooth can be anywhere and megasquirt can compensate? Quote Link to comment Share on other sites More sharing options...
AkRev Posted October 14, 2014 Share Posted October 14, 2014 (edited) Read here. I would mount it like it describes here, 9 teeth advance. Also, the tooth angle is for small adjustments, it will start to give you issues if you adjust it too much. http://www.diyautotune.com/tech_articles/trigger_wheels_overview.htm Edited October 14, 2014 by AkRev Quote Link to comment Share on other sites More sharing options...
