Multiple Camber Adjuster Spacers?
I have 17" wheels(245/40/17 tires) and with my car lowered to 5" under the front crossmember (I think that is 6.5" at the rocker) the front control arm is almost flat. I would like a bit of camber gain under bump and I already have the thickest bumpsteer spacers I could find(30mm). It is illegal to move the inner lca pivot in SSM so the only way I can think of to get some camber gain and closer to normal roll center is to add another thinner spacer.
I'm thinking 1.75-2.0 inches total spacer as I think I have that much room. The toe end would probably be the limiting factor for hitting the wheel.
Is it a good idea?
Is there another idea?
