Guest 1z2c Posted January 28, 2001 Share Posted January 28, 2001 Has anybody used the one wire alternator setup on a v8 conversion? I would like to use this setup to get rid of some wiring. It just seems simpler to hook one wire. Quote Link to comment Share on other sites More sharing options...
pparaska Posted January 28, 2001 Share Posted January 28, 2001 I haven't used one, but I've heard they don't turn on until the RPMs come up from idle. Anyway, I actually went away from the 1-wire idea to put an idiot light for the alternator in the dash area. I wanted to know if I threw a belt or toasted the alternator. It's only one more wire, and you just run from +12V to the light bulb, then to the field connection on a regular internal regulator type alternator. ------------------ Pete Paraska - 73 540Z - Marathon Z Project pparaska@home.com Pete's V8 Datsun 240Z Pages Quote Link to comment Share on other sites More sharing options...
Guest kc6wfs Posted January 29, 2001 Share Posted January 29, 2001 Hi, I am using a 1 wire alt with no problems, Yet. I just connected it to the white/red(thick) wire when I did my JTR conversion. It is true that you have to bring the R's up to 2K before it starts charging but I have not found that to be a problem. Hope this helps. I have pics if it on my web site below. Dave Booth ------------------ www.geocities.com/kc6wfs/240z.html Quote Link to comment Share on other sites More sharing options...
Guest 1z2c Posted January 29, 2001 Share Posted January 29, 2001 Thanks for the info ! Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted January 29, 2001 Share Posted January 29, 2001 I also run a one wire.Mine also kicks in at 2000,but that's just to activate it.It does charge at idle after you activate it. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 29, 2001 Share Posted January 29, 2001 I have found the high "cut-on" rpm to be a bit of a nuisance but I suppose that is all about what you want. I use a GM alt on my L6 and it was a little hesitant to come on at idle. After switching on, it keeps charging but barely. My voltage gauge reads very low until I get just above idle. I bought a smaller pulley from March Performance. It will get those idle rpms up. It was approx. $40 and a special order from Summit or Jeg's. Craig Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 22, 2001 Share Posted March 22, 2001 Since you brought it up ?? Which GM alternator can be adapted to thr I6? Also what mods are required to mount it? Thanks Tim in Fla. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted March 22, 2001 Share Posted March 22, 2001 Just log on to Craig's Ideal-z.com site and you'll be in business! Lotsa good information on there as well! Hope this helps you out. David Quote Link to comment Share on other sites More sharing options...
