Project1 Posted January 24, 2015 Share Posted January 24, 2015 (edited) This might be a stupid question, if it is just tell me. I have been reading and trying to understand setting up my frist MS. I was wondering if it would work well to run a jeep TB, then can come in a 62mm bore, and have a map, IAC, and a TPS attached. Any thoughts Edited January 24, 2015 by Project1 Quote Link to comment Share on other sites More sharing options...
dexter72 Posted January 24, 2015 Share Posted January 24, 2015 You wont need a map since Megasquirt has one inside of it. You just connect a vacuum hose from your engine to the port on the Ms unit. Quote Link to comment Share on other sites More sharing options...
Project1 Posted January 24, 2015 Author Share Posted January 24, 2015 (edited) I saw some people do that, but I still some people run them ..and some people run two in altitude (have two specific air/fuel mixtures). I'm still learning about ms. Do anyone use any other TB, for sensor reason? Or is there any other factory or aftermarket parts that people have had good luck with for using with their sensors, like the jeep TB above that has the sensors built in? Edited January 24, 2015 by Project1 Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted January 24, 2015 Share Posted January 24, 2015 The ka24e throttle body will bolt right on and has a usable tps. You'll just need to connect the throttle linkage. I personally do not use iac or fast idle. Quote Link to comment Share on other sites More sharing options...
Project1 Posted January 24, 2015 Author Share Posted January 24, 2015 (edited) The ka24e throttle body will bolt right on and has a usable tps. You'll just need to connect the throttle linkage. I personally do not use iac or fast idle. ok awesome, thats the plan I will start with. Thanks Skirkland, I appreciate your help! Is the tps on the ka24e plug and play with MS, like the GM sensors? Edited January 29, 2015 by Project1 Quote Link to comment Share on other sites More sharing options...
