Turbo Oil Pump (AUTO OR NOT)
Ron240zxt
The A/Ts have an OEM oil cooler air/oil and M/Ts do not. I assume the A/T pump is a higher volume pump and if you think you'll run an oil cooler the A/T would be the better choice. Just a side note, an interesting feature of the LD28 engine is a water/oil cooler unit incorporated into the oil filter base assy.
DAW
