socorob Posted February 13, 2015 Share Posted February 13, 2015 This may have been done already, but I couldn't find any info. I wanted to put in a power antenna with manual operation being able to use the stock Z switch. I used a Harada MQ1 antenna and 2 SPDT relays. Here's the wiring diagram if anyone is interested. It uses all existing wires from the harness without needing to run any more wires to the back of the car. When you're looking at the plug that's inside the fender by the rear marker light, the bottom sideways connection is ground, the right is up and the left is down. Quote Link to comment Share on other sites More sharing options...
socorob Posted February 13, 2015 Author Share Posted February 13, 2015 Forgot to attach the relay wiring. Quote Link to comment Share on other sites More sharing options...
WhyTheFudge Posted January 10, 2024 Share Posted January 10, 2024 On 2/12/2015 at 10:26 PM, socorob said: Forgot to attach the relay wiring. Is that antenna fully manual, as in you have to stop pressing the button and it stops or does it have internal limit switches that will stop the motor running when full up or down? Quote Link to comment Share on other sites More sharing options...
socorob Posted May 5, 2024 Author Share Posted May 5, 2024 fully manual Quote Link to comment Share on other sites More sharing options...
