What size hose for MAP sensor?
danigrrlz
http://www.diyautotune.com/catalog/mpx4250-25-bar-map-sensor-p-106.html
DIY autotune lists this as the sensor for PCB 2.0 & 3.0 (probably 3.57 too, I have a 3.57 and the sensor looks pretty similar to this) You could open it quickly and verify you have the same MAP sensor.
http://cache.freescale.com/files/sensors/doc/data_sheet/MPX4250A.pdf is the spec sheet for this sensor. Pg 9 shows a 4.93mm nipple - thats very very close to 3/16".
