Is this the correct way to wire for edis&vr sensor
wickiewicked240z
is this the correct way to activate EDIs on a MS2 3.0 board
The red is what needs to be done correct? On the wiring guide it says to
jumper tach select to XG1(but theres all ready jumpered tachselect to vrin) do i add another wire from tach select to xg1
Jumper opto out to tsel
But to wire the vr sensor it says to tachselect to vrin(which it is already)
wire TSEL to VROUTINV on the other section of the guide it says to wire it to opto out
Look up DIY Auto.com They have a writeup for running MS2 3.0 for EDIS..  From what i read, MS2 3.0 are pre-wired to run edis out of the box, if its from DIY. That may be why yours has already been jumpered.
Just wondering, are you going to use a crank trigger wheel??..
Edited by dexter72
