DavyZ Posted December 24, 2001 Share Posted December 24, 2001 Grumpy, Lonehdrider knows (I think so anyway) but is away for a while You might try to email him while he is out of state. (remember that his brother had a bad motorcycle accident and he is in AZ for a while). Look for his email address on one of his posts. Sorry I can't help much, but I know those things are out there. Davy Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 24, 2001 Share Posted December 24, 2001 Damn, YES, I've seen one. It was on a GN site as I recall but looking through the bookmarks on this computer I didn't see it. How quickly do you need it? Also, have you considered making a sheetmetal elbow and using a Ford TB? This is how I'm going - elbow for under $100 I'm told. I've got a laptop that MIGHT have a bookmark for this but it's been acting flakey lately. I'll look as soon as I get a chance - ding me on my HotMail account if I've not posted back in a day or two. Hrm, someone made one for the Ford guys too but it couldn't be turned to face forward (I tried). Argh, this is going to drive me nuts trying to remember where I saw it... Here's the Ford unit - still looking... Ah Ha! http://members.aol.com/bigturbo1/buick1.html Found it in one of our ChevyTalk discussions. Unfortunatly it's NOT a GM type TB but it's the best I've been able to find. Is there a reaosn the Ford TB won't work for you? They're cheaper but I'd imagine you may already have some and cable routing might be an issue... Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted December 24, 2001 Author Share Posted December 24, 2001 does anyone know of a source for an adapter (other than the one made by ACCEL)that adapts a gm TPI throttle body like the ones on the TPI L98 engines to a 4-barrel carb mounting pattern this is a 90 deg. adapter! ?????? one end of the adapter bolts to a 4-barrel carb mounting pad the other bolts to a twin bore GM throttle body. the buick GN turbo cars use something simular but not interchangeable Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted December 24, 2001 Author Share Posted December 24, 2001 thats very close to what Im looking for but like I said it must fit a G.M. dual bore TPI style throttle body and bolt to a standard 4-barrel mounting flange,that adapter(I called the supplier) will not bolt to either, but hey ,very good try and no one else even came that close so far, thanks for the help!PLEASE KEEP LOOKING! Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 25, 2001 Share Posted December 25, 2001 That bottom elbow won't bolt to a 4barrel flange?! Whew, glad I didn't order one! Have you considered making one? The fabricator doing my intake conversion is supposed to make me a conversion elbow but for a Ford TB. A GM TB shouldn't be too much different should it? Is the Accel elbow simply too expensive or made from unobtanium? I seem to recall it was pricey but then all of the GM TBs, MAFs, and intakes for EFI seem to be awful expensive Thankfully I'm not strapped to a GM TB Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted December 26, 2001 Share Posted December 26, 2001 The Buick StageII engine that was used in the Busch GN series were carbureted and made phenominal HP. The intakes are so good that the Buick turbo folks uses that adaptor to get a huge TB on the intake and make the necessary mods on the ports for injectors. Quote Link to comment Share on other sites More sharing options...
