Wire Management - HIDs
NgoZ
Finished installing HIDs from Dapper and wanted to know how some of you guys hid your wiring. I was able to hide a lot of the wiring towards the battery using wire loom and existing wiring which cleaned that up, but towards the front where the ballast are it gets interesting and a bit tight. Currently I used double stick tape to hold the ballast down (and suppress some of the vibration) and tie wrapped the wires under existing looms and stuff.
Just looking for some ideas and pictures to make it a cleaner install.
If you have thought about upgrading, use Dapper Lighting's kit was pretty easy and quality was top notch. Instructions were good and detailed, only thing you need to know is that you have to cut out the back of housing to fit it correctly in a 280z. It really made a big difference from the stock setup and I can actually see driving down the road now.
