anyone have a pic like this?
Guest mtj71Z
Guest mtj71Z
anyone have a picture like this of a 240Z and a little more focused to the steering wheel wires?
i have some wires sticking out and i have no idea why....but my turn signals dont work tongue.gif
Guest SpudZ
It looks like a 68 ' to 70' high windshield car.
I had three 2000's . I am down to just pieces
of one.
Guest mtj71Z
there is a short green female wire coming out of the turn signal. then there is a long green female wire going into somewhere deeper. there is a female black with yellow and a male blue with white......and also 2 black wires that are just in front of the firewall. but they are cut......
Guest SpudZ
Let me know what year Roadster it is and I will look up the wiring schematic
or look at my Roadster in the backyard. I can try to locate the link to the Roadster
wiring schematics there is a place on line with them.
73' 240
Go here:
http://240z.jeromio.com/ac.html
I think that, for the most part, the wires do only connect one way, as in, you can't inadvertantly switch wires around.
If you signals aren't working, chances are good that it's cuz the crappy switch mechanism is gurbed up. This is VERY common. I have had mine apart twice to get it working again. It's always a temporary fix. The stupid design has all the juice running thru the lame little switch.
Pete has a really good write up about a fix: http://mywebpages.comcast.net/pparaska/turnsgn1.htm.
I was gonna do that, but then I got sidetracked. I am planning on following Owen's lead and doing this:
http://www.v8zcar.com/s30z/turnsigassy.htm
which may happen in conjunction with Pete's Relay system.
