stock l28e EDIS Base Setup/map?
bahelion89
The base tune should be the same as the tunes in Megasquirt map sharing section. Just find one that comes close to your setup and copy it.
  If your using Megasquirt and your initial settings are changed for Edis ignition, you should be good to go for a start.
I also like to make sure i have spark first, before letting fuel flow to the rail.
