Turbo distributor to MSD 6A installation help!
Hi everyone,
I'm looking for help on how to install the MSD 6 into a turbo distr or E12-80 distr. i basically follow the msd manual wiring all the neccesary wires. I have both of distr set up, either one work should be fine for me. I know the E12-80 distr is a point distr.
i currently have the 240z wiring harness out of the car for troubleshooting for short issues.
My set up;
-l28et
-z31 ECU
-low impetance injectors
-280zx stock harness
-MSD 6 ignition module
-MSD blaster 2
-E12-80 distr
Here are my main questions:
1- if i use the E12-80, i know the C terminal is going to the MSD input (white). Do i also need to loop this to the ECU too? If so, what pin should i connect it to?
2- if i use the turbo distr, which terminal is the output signal to the MSD? And how to wire them correctly?
3- is the turbo distr also a Point trigger?
4- who is tell the ECU to open the injectors?
Thanks for all the input in advance!
Kevin,
